Lionelwiseman
- Joined
- Dec 20, 2010
- Messages
- 5
- Reaction score
- 0
- Points
- 1
I have recently bought a Panasonic DMR-BW880/780 (not sure which!). It was bought to replace a malfunctioning Panasonic DMR-R95H recorder. The new recorder works fine, however, when attempting to use a DVD RAM disc that was originally used on the old recorder, the new recorder happily plays the title on the RAM disc but the title cannot be deleted and new titles cannot be ‘dubbed'/copied from the HDD to the RAM disc. Also I do not seem to be able to reformat the RAM disc.
Any ideas or comments would be appreciated.
The RAM discs come in a caddy. On the original recorder the DVD tray accepts the caddy, however, on the new recorder the discs have to be removed from the caddy.
The discs are Panasonic DVD-RAM, 240 min (120min per side) , TYPE 4, 4.7 GB per side (i.e. rewritable, double sided)
