DVD-RAM players
Discussion in 'Blu-ray & DVD Players & Recorders' started by dunlop73, Aug 20, 2003.
  1. dunlop73
    dunlop73
    Aug 11, 2003
    95
    Birmingham
    +5
    It's a long story, but I've just managed to get a refund on my Philips 890 (2 days before the guarantee runs out!!) and have replaced it with a Panasonic E50. So far it feels much better made and more sophisticated (and actually works).
    I would like to be able to play (and possibly transfer to DVD-R) DVD-RAMs on my PC (which has a DVD-R writer) so I need a DVD-ROM drive which can read them. Can anyone point me in the right direction?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,203
    Argyll
    +2,260
    The Toshiba 1612 DVD-ROM reads them and is also cheap. Available from Dabs (www.dabs.com) or in-store at PC World. Probably best to try the latter first as it tells you on the box it plays DVD-RAMs.
    I should also test the DVD-ROM drive you already have. I actually had the above Toshiba supplied (without asking) by Evesham when I ordered my current PC.
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,203
    Argyll
    +2,260
  4. fremar
    fremar
    You can buy a PC based DVDROM drive that reads DVDRAM from here.
    Toshiba SDM-1712 £32.96 delivered from www.cclcomputers.co.uk
    fremar
  5. jimmyboy
    jimmyboy
    Does you E50 playback DVD-RW? or mp3? (Not listed on the above site)
  6. dunlop73
    dunlop73
    Aug 11, 2003
    95
    Birmingham
    +5
    Plays Mp3 discs really well - much better system than the Philips. I haven't tried a DVD-RW yet, DVD+R plays well, but DVD+RW is not recognised.
    Just got back from PC World with an LG GDR-8161B DVD-ROM drive which is DVD-RAM compatible - no Toshiba in stock, but the LG was only £39.99 so I guess that's OK - still £60 up on the deal as I got £500 back for the Philips.
    :cool:
    Early impressions of the Panasonic are great! Excellent quality thanks to best fit mode - really easy editing too - I had been a reader of another forum which had led me to believe only the DVD+RW system could be edited on the machine. Very happy so far!!
    Cheers for advice
    Jon
  7. bobbles
    bobbles
    if you want to transfer edited RAM to -R then an altenative might be an S35 which can play RAM and very importantly has component outputs
    you can get a multiregion modded version for around £100
    This also gives you the option of archiving from sky(+) onto RAM whilst watching a DVD
    worth thinking about
  8. dunlop73
    dunlop73
    Aug 11, 2003
    95
    Birmingham
    +5
    Hmm. Wouldn't that compromise the quality a bit? I had thought that doing it in a computer would mean the video part would be a digital copy rather than a recording of a copy which is what I would get through another DVD player.
    Jon
