DVD RAM player...?
Discussion in 'Blu-ray & DVD Players & Recorders' started by wellsi, May 13, 2002.
  1. wellsi
    wellsi
    Mar 28, 2002
    494
    London, UK
    +29
    Hi guys,
    So, after having lots of fun recording on the Pansonic DMR-E20, I've realised it would be nice to have an additional DVD-RAM player.
    There are so many more editing features available when you record to DVD-RAM and it would then be great to transfer your finished product onto a £1.50 DVD-R, rather than keep it on a £15 DVD-RAM, as well as making copies for other people. Solution would be to have a seperate DVD-RAM player to copy from.
    I read that the new DVD-Multi standard would cover DVD-R, DVD-RW and DVD-RAM discs; wondering if there were any DVD-Ram players out there yet...? Anyone seen one?
    Cheers,
  2. lbeck
    lbeck
    Apr 18, 2002
    33
    Ian,
    It appears that you and I are tracking the same line. Also a new E20 user, I'm looking forward to the next step of being able to work between DVD-RAM and DVD-R, though It'll be a while. I 'm still on an E20 high, and won't need (i.e., can't afford) another electronics fix for a few months. However, there appears to be a relatively inexpensive DVD burner at:
    http://www.zdnet.com/supercenter/stories/overview/0,12069,539052,00.html
    Aslo, an apparently really inexpensive DVD-RAM reader (about 53 pounds) menitoned in this forum at "DVD-RAM to DVD-R." I tried cutting/pasting the URL here, but it's apparently too long. Let me kmnow if you can't locate the discussion thread.
    I'm thinking of going the read/write route so that I can play with my video editing software on my computer, get it as perfect as I want, write to a DVD-RAM, then transfer to DVD-R (e.g., compilations of home video to distribute to family). A RAM to -R capability may enable me to do most of my DVD work on the computer, but I still like the E20 as a high-end VCR (or V-DVD-R) and for convenient playback of DVDs since my computer and E20 are in different rooms.
    Let me know what you find out about other RAM writers and/or readers. I'll continue to monitor this webboard.
  3. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
  4. wellsi
    wellsi
    Mar 28, 2002
    494
    London, UK
    +29
    Alanrob!
    You're not wrong! 89p inc vat for dvd-r ain't bad!
    Now, if dvd-r is 89p, why is dvd-ram still so pricey...?
    Thanks to the other guys for your thoughts on RAM to dvd-R; might well get a RAM writer for the PC and hook the two up...
    Cheers,
  5. malcom
    malcom
    Aug 25, 2001
    526
    +4
    wellsi
    Just a reminder! It seems that DVD-RAM players to-date do not have a seamless playback option. So any edit points you have created on your RAM disc will show up as brief freeze frames.
    With a lot of edit points this could be quite annoying depending on your taste. Good luck. Malcom.
  6. wellsi
    wellsi
    Mar 28, 2002
    494
    London, UK
    +29
    Think it might be best to wait for the next lot of set top dvd players to come out, with RAM reading ability too...
    Cheers,
  7. encaser
    encaser
    Mar 15, 2001
    3,584
    Suffolk/Essex
    +1,196
    You guys may care to know that Dixons (don't know if all branches) have been selling the above PC dvd ram (only, no dvd-r) writers for about £100.
    If you want seemless playback then record to dvd-r on your E20 this may be a solution.;)
    Stores are finding it hard going flogging DVD-RAM only writers due to dvd-r under-cutting costs of RAM discs, so this may be a bargain for you archivers with an E20? Don't know if the E20 will do seemless record to dvd-r but you should!!!:p
  8. wellsi
    wellsi
    Mar 28, 2002
    494
    London, UK
    +29
    I got a DVD RAM drive (Toshiba SD W2002) as it stated it also read DVD-R. Upon installing it, (and confirmed with Toshiba), it only reads the old 2.7 Gb DVD-R, which of course, no one uses anymore.
    It's gone back to PC World, and I'm now awaiting the Panasonic PC RAM / DVD-R writer drive...
  9. encaser
    encaser
    Mar 15, 2001
    3,584
    Suffolk/Essex
    +1,196
    Which one, the LF-D311 @ £350? Nice that it has R as well.
    What is the E20 like at play back, would you rate it?
  10. DaveP
    DaveP
  11. wellsi
    wellsi
    Mar 28, 2002
    494
    London, UK
    +29
    Encaser...
    Yep, it the LF-D311; £359 from jungle.com including a firewire card and some smart video editing software too.
    Anyone who's read any of my posts will know I love the E20; it's features and playback are great. Only gripe is a really messy remote control and no built in hard drive to copy RAM onto DVD-R. Those two issues are resolved in the next release; due out late this year, when it gets a built in 40Gb hard drive...
    Cheers,
