dvd ram or dvd-rw or r?
Discussion in 'Blu-ray & DVD discs' started by gabbyevs, May 16, 2005.
  1. gabbyevs
    gabbyevs
    Aug 14, 2004
    154
    ive just orderd a panasonic recorder and was wondering if someone could tell me wots the best disc to have
    i know dvd-r cant be rewritten over so would it best to get a ram or rw disc for recording programs?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    What DVD recorder is it? DVD-RAM will enable all the features of the machine, i.e. timeslip, editing and so forth, but won't playback on other DVD players. DVD-RW will act as compatible re-writeable media but with minimal features. And DVD-R provides near universal compatibility but minimal features. Therefore it is probably best to get some of everything!
  3. gabbyevs
    gabbyevs
    Aug 14, 2004
    154
    its a panasonic dse10
    wot minimal feature are theere on the rw?
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    If you use DVD-RW then you will be able to record in a linear way like a VCR. Your recordings will play on most, but not all, DVD players. Features you'd be able to use on the DVD recorder though are limited to (more or less) titling the recording, deleting it and formatting the disc.
    If you use DVD-RAM you will not be able to play on other DVD players (unless it is a DVD-RAM capable player/recorder) but will be able to use simultaneous record/playback, editing, playlists (non-linear playback - ideal for music!) and be able to re-use the disc again and again without formatting/finalising.
    Have a look at the differences between the formats and an explanation of VR and Video mode for further info.
  5. gabbyevs
    gabbyevs
    Aug 14, 2004
    154
    thanx for that i think i understand it better now!
