DVD-RAM media for Panasonic E55
Discussion in 'Blu-ray & DVD Players & Recorders' started by chiyoaiki, Jul 5, 2004.
  1. chiyoaiki
    chiyoaiki
    What is a good DVD-RAM media to use with Panasonic E55? Which brands work well with E55? Is there any particular brand that I sould avoid?
    Thanks.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    22,036
    Warwick
    +2,901
    As DVD-RAMs are more complex to make than DVD+-R/Ws there is not the problem of unlicensed Chinese producers and thus 'most' DVD-RAMs should be of good quality. However personally I prefer to stick to 'brand names' such as Panasonic, Maxell, Verbatim and TDK - especially as DVD-RAMs form an essential part of my backup system.
    DVD-RAMs can be got reasonably cheaply here:
    http://www.dvd-and-media.com/dvd-ram-media.htm
    Panasonic disks can be got at reasonbale prices from the Panasonic E-Shop:
    http://eshop.panasonic.co.uk/shop.aspx
    If you after some cheap disks then SVP have them for under £2 although I have never tried them:
    http://www.blankdiscshop.co.uk/acatalog/FOR_DVD_RAM___CLICK_HERE.html
  3. chiyoaiki
    chiyoaiki
    What do "non caddy" and "non-cartridge" mean?
    Thanks.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    22,036
    Warwick
    +2,901
    DVD-RAM disks can come in square protective cartridges that protect the disk from damage. Ideal if you have kids, pets or anything else that damages media.
    However most DVD-RAM compatible devices only take non-caddy DVD-RAM disks and so many disks are now sold without cartridges - instead they are covered with a special coating that offers protection to the disk. If you are using DVD-RAM disks with your PC frequently I suggest getting the non-caddy version as it saves the hastle of removing/reinserting disks from their caddies.
    Just for your reference the main types of DVD-RAM disk and their definitions are:
    Type 1
    Double Sided disc mounted permanently in a protective cartridge.
    Type 2
    Single Sided disc in a protective cartridge, but the disc can be removed from the cartridge for playback in DVD-ROM drives that have DVD-RAM playback capability.
    Type 4
    Double Sided disc in a protective cartridge, but the disc can be removed from the cartridge for playback in DVD-ROM drives that have DVD-RAM playback capability.
  5. chiyoaiki
    chiyoaiki
    How many time can you re-write a DVD-RAM? Is there an upper limit on number of times? Will I need to format the disk before using each time? What happen if I finalize the DVD-RAM, can it be used again?
    Thanks.
  6. Rasczak
    Rasczak
    Apr 3, 2002
    22,036
    Warwick
    +2,901
    Upto 100,000 times (as opposed upto 1000 times for DVD+-RW).
    No - the erase or partial erase can be used. Each frees up disk space meaning there is no need to format.
    You don't finalise DVD-RAM disks - they work like a removeable HDD, i.e. you do not have to finalise them to allow DVD-RAM readers to 'see' them. Your E55 will not give you the option to finalise a DVD-RAM.
  7. dude1971
    dude1971
    Smart Buy Ram is only £1.49 and it's been fine for me.
    Welcome back Rasczak!
    Regards
    Darren
  8. volvofl10
    volvofl10
    Jun 17, 2004
    79
