DVD RAM Format Software
Discussion in 'Computer Components' started by meansizzler, Aug 26, 2006.
  1. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Finally found some DVD RAM Format Software, instead of using the one built into windows, was able to format my incorectly formatted DVD-RAM disc..., try for the past year to try and reformat it with loads of software but none of them could ever save it...also Formats to UDF.., why not send a thankyou to Toshiba for this, was busy trying to find out the software that came supplied with the HD-DVD ROM equppied QOSMIO G30 when I stubbled upon it..
    DOWNLAOD
  2. Paul Shirley
    Paul Shirley
    Sep 27, 2004
    1,354
    63
    +174
    You can use Nero InCD for this and its what ships with some drives (LG is one) instead of the Panasonic drivers. Personally I prefer the Panasonic ones (InCD being a buggy POS) but they tend to take a while to gain support for new drives.
