DVD-RAM editting on a PC
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by crawf1982, Jan 13, 2003.
  1. crawf1982
    crawf1982
    Jun 21, 2002
    188
    East Midlands, UK
    +7
    Ok, here's what I want to do...
    Take DVD-RAM discs burned on my Panasonic DMR-E30, edit the video on my PC and burn to a DVD-R (for example - I would use this method to put the new series of Friends onto DVD-R having removed all the adverts and added some menus)
    What software do I need on my PC to edit the footage from the DVD-RAM discs? What conversions do I need to go through? Will I be left with a perfect copy after editting?
    In case anybody is interested I will be using the new Toshiba SD-M1712 DVD-ROM drive to read the info off the DVD-RAM discs - you can get this drive from dabs.com for under £40 - very handy.
    Many thanks,
    Dave
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Have a look here
    Some great apps and guides that should give you a start.
  3. bobbles
    bobbles
    trying to decide between the panny and philips systems
    your idea is ideal for me, but i do not have a dvd writer on PC
    you say you have got a DVD-ROM drive for £40 from DABs to read the disks but what are you going to use to burn onto dvd-R
    do you need two separate drives?
