DVD-RAM double sided - why bother?
Discussion in 'Blu-ray & DVD Players & Recorders' started by derb, Mar 30, 2003.
  1. derb
    derb
    Am I right in thinking that the Panasonic DVRs can't read both sides of a DVD-RAM disc without you having to eject and turn it over? (should have checked the manual for the Panny E50 when in-store!)
    Is there any reason (other than storage space) to buy (rarer) double sided instead of single sided discs?
  2. DaveP
    DaveP
    No reason at all! They shoud be cheaper than buying two though.
    DaveP
  3. bobbles
    bobbles
    I actually think double sided RAM cost more than 2 single
  4. jryoung
    jryoung
    Aug 8, 2000
    35
    Guildford,Surrey,UK
    Well, I quite like the double sided caddied discs. But its personal preference. I posted a question about it before I bought my E30
