dvd-ram disks dont work on my panny hsr-52
Discussion in 'Blu-ray & DVD Players & Recorders' started by eternaldark, Oct 23, 2005.
  1. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    I have both a panasonic E-95 and the dmr-hs2 I bought a pack of panasonic dvd-ram disks (non cartridge 3x speed) and although they work fine on the E-95, I cannot use them to record on the dmr-hs2 although I can view the recordings made, I cannot dub them to the hard drive or record anything new onto them I just get an error message saying this is a non recordable disk!
    I tried formatting them on the 95 to use on the other recorder and doesn't work.
    Is it because they are 3xspeed?
    bit annoyed because i thought they would be compatable :lease:
    Edit - Just found a firmware update for the HS2 on the panasonic usa website, would this help?
  2. sean5302
    sean5302
    Sep 21, 2005
    1,425
    48
    +82
    Believe it or not, I had just this problem with Panasonic RAM discs.
    I was shocked when I rang the Panasonic helpline and was advised to source Maxell RAM discs.
    Very, very hard to find but ebay helps.
    Maxell's worked fine and dandy.
    Answers on a postcard? Well, here will do.
  3. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    cheers, will keep an eye out on ebay they has some but weren't recommended for home dvd-recorders.
    Had a look at pannys shop website incase they sold 1xspeed ram disks for compatability and all their ram disks are 3x speed :mad:
  4. sean5302
    sean5302
    Sep 21, 2005
    1,425
    48
    +82
    The ones I couldn't use were:
    LM-AF120LE5
    2 to 3x speed, 120 min 5-pack, from
    argos.
  5. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    Think that most of the DVD-RAM discs are 3x nowadays. You can purchase cheaper than Argos.
    Blankdiscshop have spindles of ten dvd-ram discs
    at £14-99. Two different makes just as good as Panasonic or Maxell. There isn't all that much difference in dvd-ram quality between different makers. Postage is £4-99 for next day delivery so now is a good chance to also purchase some DVD-R discs.
    http://www.blankdiscshop.co.uk/acatalog/dvdram.html
