DVD-RAM and DVD-R question
Discussion in 'Blu-ray & DVD Players & Recorders' started by pandrew, Sep 24, 2003.
  1. pandrew
    pandrew
    Dec 20, 2002
    38
    Could someone tell me the answer to this question
    If I was to buy a DVD-RAM or DVD-R disk from the US, would it record/play ok on my Panasonic E50, UK spec?
    Would I have to format them first?
    This may be a silly question but I don't know the answer.
    Thanks in advance.
  2. nwgarratt
    nwgarratt
    May 5, 2002
    27,152
    +3,022
    Yes it would.
    The E50 records in either PAL or NTSC. If you recorded TV you just record in PAL just like a VCR.
  3. pandrew
    pandrew
    Dec 20, 2002
    38
    Does that mean I couldn't buy a blank DVD-RAM or DVD-R from the US and record onto it using my E50 (UK spec) then watch it back on my machine?
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    You can record onto DVD-RAM or DVD-R sourced from the U.S. on your U.K. machine
  5. pandrew
    pandrew
    Dec 20, 2002
    38
    Thanks everyone.
    I mis-read nwgarratt reply. Sorry for being a bit thick.
  6. nwgarratt
    nwgarratt
    May 5, 2002
    27,152
    +3,022
    Perhaps, I should have not mentioned the NTSC bit as it is not relevant.
    A blank disc is just that, its up to the equipment that makes the format you watch it in.
