dvd r/w
Discussion in 'Blu-ray & DVD Players & Recorders' started by patmyhead, Jun 15, 2003.
  1. patmyhead
    patmyhead
    Feb 11, 2002
    588
    I o M
    Hi Any one recermend a external dvd rewrighter for
    my laptop that will record to a dvd that my arcam 88 dvd player can play back
    P@
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    Refer to www.dvdrhelp.com for what type of disks your Arcam is compatible with. A brief look suggests it will play DVD-RW/-R as well as DVD+RW/+R so I would suggest the format you get doesn't matter to much.
    Can't really help with which specific unit to get though as I've never used any external DVD burners.
  3. lurcher
    lurcher
    May 15, 2003
    4,163
    Stalybridge
    +221
    I use a Pioneer 104 housed in a firewire box and it works a treat with my laptop.
  4. ferris57
    ferris57
    Jan 18, 2003
    869
    if money is no object and you have usb2 or firewire then the external version of the dual format sony burner is about the best one on the market.
