dvd-r to hdd on Panasonic hs2
Discussion in 'Blu-ray & DVD Players & Recorders' started by Lumox, Feb 15, 2003.
  1. Lumox
    Lumox
    Can't seem to record from dvd-r disc to the hard drive on a Panasonic hs2, so I can not
    make a copy. Is there a way to copy dvd-r on this machine.
    Thanks.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,210
    Argyll
    +2,265
    You can only copy from DVD-R to HDD if the disk is not yet finalised. Panasonic didn't build in this function for obvious copy protection reasons. My suggestion here would be to either purchase a cheap DVD burner for your PC or take the disk down to a DVD burner equipped Internet Cafe and burn it there.
  3. Lumox
    Lumox
    Would it be possible then to record the dvd-r disc from a cheap dvd player to the hs2 via the scart socket.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,210
    Argyll
    +2,265
    Yes as the DVD-R doesn't have any sort of copy protection. You should be able to link any DVD player that can play DVD-Rs upto the HS2 and copy the DVD. Obviously there will be a slight drop in quality (how much depends on your setup) but, whatever, it should be minimal.
