DVD-r to Digital Video Tape?
Discussion in 'Blu-ray & DVD Players & Recorders' started by steve 111, Dec 13, 2004.
  1. steve 111
    steve 111
    Jan 5, 2003
    551
    Newport, Gwent
    I have some footage on DVD-r that I wish to transfer onto tape on my Digital Video Camera (JVC GR-DX67).
    If I have my DVD recorder connected to my DV camera via firewire is it as simple as pressing play on my DVD recorder and record on my DV camera?
  2. johnjackthom
    johnjackthom
    Sep 20, 2001
    714
    Northumberland
    +250
    As I understand it, the firewire port on DVD recorders only works as an input; ie for recording from DV camcorders. :(
    The best you can probably do is use an S-Video + audio connection between the two.
    There will no doubt be a PC solution to this one but may involve some time as well as cost in finding the right software. Might be worth asking for advice on the Camcorders & Video Editing forum.
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Firewire is two way
    Basically rip the DVD to the PC and pull it into an editing package then save to the DV camera.
