DVD-R\-RW vs DVD+R\+RW
Discussion in 'Blu-ray & DVD Players & Recorders' started by Billilu, Nov 7, 2003.
  1. Billilu
    Billilu
    What a crazy situation we do find ourselves in, even after all this time. Progress, eh?
    I have the Pioneer DV-868AVi on order from Joe, and also on order I have a new computer from Dell. Thanks to my Dad, I have realised that the DVD writer I have ordered on my computer is the little used DVD+R\+RW, and that the 868 only plays DVD-R\-RW.
    Is this a correct assumption? Could I therefore end up burning DVDs on my computer that I can't then play on my DVD player? Or is there a way round this?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,203
    Argyll
    +2,261
    The DVDR market is seriously screwed up! You have the official formats DVD-RW and DVD-R and the DVD Alliance (Philips, HP, Dell etc) alternative DVD+RW and DVD+R. I wouldn't say + is less used - the market is split about 50/50. Pioneer invented the 'minus' format though so support it quite strongly. You MAY find that DVD+R will play on your Pioneer - you might even find DVD+RW will.
  3. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    I used to have a Pioneer 747. It's specs showed -R/-RW support (mentioning nothing about "+" discs). It did however play +R/+RW fine.
  4. chrisowe
    chrisowe
    Apr 17, 2003
    467
    Anywhere
    +16
    I've just bought a Pioneer 565 and although they only mention it plays DVD- it does indeed play my DVD+ discs.
  5. Billilu
    Billilu
    This is very reassuring. Thanks. I won't ring up Dell and insist they change it to a Pioneer DVD writer then.
    Mind you, it would be great if it could be confirmed that the 868 will be able to play DVD+R and +RW, but then we don't even know if we're getting an HDMI cable with it yet.
  6. splnter
    splnter
    Oct 20, 2003
    517
    Basingstoke. Hampshire
    +25
    Hi, I have a panasonic cx dv1500 , mobile dvd player,
    And this will play + discs but wont play -, so i phoned panasonic up and they said it should not play + discs only - ??
    as there format is - hahaha. Its all nuts if you ask me. :rotfl:
  7. Harry T
    Harry T
    A quick check of this site
    Click here
    Doesn't list the DV868, but you will be able to see that nearly all Pioneer players are compatiable with +R/RW format
  8. alan8477
    alan8477
    Dec 17, 2001
    574
    Pershore
    +5
    I have a 565 and it will not play my +R or +RW discs, so it looks as though it varies with batches.
  9. Billilu
    Billilu
    Thanks for that. The answer seems to be, it's likely but don't hold your breath.
    Crazy.
  10. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    To throw another spanner in the works......
    It also depends on the software used to create the disks, and often which make of disks. :rolleyes:
    Mark.
  11. Ged
    Ged
    Apr 29, 2002
    922
    +17
    Don't panic, I have an LG 4040B, does every format even RAM for £120, if your discs don't play you can upgrade, probably dropped by £10 already....includes alot of software...
  12. chrisowe
    chrisowe
    Apr 17, 2003
    467
    Anywhere
    +16
    I use Verbatim + discs burned with an NEC ND1300 mostly using Clone DVD, but I have used other programs like Sonic MyDVD and they all play in my Pioneer.
  13. Harry T
    Harry T
    MarkE19 makes a valid point.
    Software and brand of disk seem to be the major issues. The other issue is the burn speed. Slower speeds appear to be alot more successful.
