DVD +R/-R compatability with DV88 Plus
Discussion in 'Arcam Owners' Forum' started by StuB, Dec 4, 2003.
Tags:
  1. StuB
    StuB
    Hi Peeps, I have a DV8 Plus, I recently got a DVD burner, and have tried to back up some of my best DVDs, I found that I can't get -R discs to play, the display says "bad disc". I then tried a +R disc that came with the burner and it worked. Have any of you other Arcam DVD owners had compatability issues with Recordable DVD media?
    Cheers, Stu
  2. robocop
    robocop
    Oct 16, 2000
    646
    Old Detroit a.k.a. Chippenham. Wilts
    +23
    What software version does your player have?
  3. StuB
    StuB
    Robocop, I dunno what it is, how can I find out?
  4. onefivenine
    onefivenine
    Nov 5, 2003
    3,351
    Edinburgh
    +616
    Have a look on here
    http://www.dvdrhelp.com/dvdplayers.php?DVDnameid=28&Search=Search&#comments
    You need to read from the bottom up. Hope it helps ( I haven;t read it all)
    I did note the following comment:-
    <QUOTE><B>
    This machine won't play DVD-R's burnt using just the UDF mode in Nero (most other players like them burnt this way) It requires UDF/ISO mode
    At least it wouldn't for me anyway</B></QUOTE>
  5. StuB
    StuB
    Cheers, I've used the code in the forum you posted onefivenine,to get my software version, it was 2.1.8.32.1/LT75/02/FF
    Loading Tray was LT75.
    I'll have a look at this UDF mode thing, see if that helps. Its not a problem per se to use +R other than the 10p extra per disc from my local dealer!! Just be nice to know why it is having compatablity problems, and improve my understanding of why these issues arise.
    Cheers, Stu
  6. szd
    szd
    Dec 4, 2000
    329
    2
    Gloucester
    +15
    I have software version 4.12.0/LT76/02/FF and use TraxData -R discs and they work fine using Nero and a Sony DVD burner (DRU-500A).
  7. robocop
    robocop
    Oct 16, 2000
    646
    +23
    That's an early software version you are using at present.
    I remember trying a DVD-R when I first had my player and it didn't work. I wasn't worried because I had no need to play DVD-R's.
    I subsequently tried it later after a couple of updates and it worked.
    It may be worth getting hold of later software.
    Give Arcam's excellent support desk a call, and they'll send you out a copy.
  8. StuB
    StuB
    Cheers Robocop, I'll give Arcam a bell, I myself will happily burn +Rs but, if anyone else lends me a -R it'd be handy tob e able to play them!!
    Many thanks for all your replies.
