DVD-R playback on a Sony DVP-CX850D?
Discussion in 'Blu-ray & DVD Players & Recorders' started by crawf1982, Dec 16, 2002.
  1. crawf1982
    crawf1982
    Jun 21, 2002
    183
    East Midlands, UK
    +7
    Does anybody know if the Sony DVP-CX850D DVD multi-changer is capable of playing back DVD-R discs?
    If not, is it possible to upgrade the firmware to allow it to do so?
    Cheers,
    Dave
  2. Flimber
    Flimber
    Sep 22, 2002
    13,719
    Yorkshire
    +4,483
    The latter is not very likely to happen; for the former look up vcdhelp on Google.
    HTH,
    Mike.
  3. crawf1982
    crawf1982
    Jun 21, 2002
    183
    East Midlands, UK
    +7
    Wow thanks!! That site has all the info you could ever wish for. Just in case anybody else is interested, the Sony DVP-CX850D seems to be very compatible with DVD-R discs - Princo and White Label Bulk Paq are 2 brands that have been tested with no problems.
    The reports on the site also state that this player is compatible with:
    DVD-RW
    DVD+R
    DVD+RW
    CD-RW
    and certain CD-R discs
    I'm VERY glad I bought this player now!! I got it 2nd hand about 2 months ago for only £175 :D
