DVD-R not play in my HS2
Discussion in 'Blu-ray & DVD Players & Recorders' started by Daveandpauline, May 28, 2004.
  1. Daveandpauline
    Daveandpauline
    Can someone point me in the right direction. I have recently bought a PC DVD writer, a LiteOn, did my first burn, the film will play in my PC and some of my friends DVD players but not in my HS2. It gives a code of U11. I have done everything, change make of DVD discs, tryed 3 top quality ones, changed the writer to a Pioneer 107D but still the same. I am using Nero. Has anybody any ideas before this PC ends up on the grass outside...!!!! :suicide: :suicide:
    Thanks Dave
  2. pgayler
    pgayler
    Dec 11, 2002
    30
    Maidenhead, Berkshire
    Dave
    I have a similar problem, on my laptop i copied a dvd film to dvd-r, it plays on my Panasonic DVD-RV31 but won't play on my DMR-E55, just says this is an incompatible format.
    Your not alone,
    any help would be appreciated.
  3. pinatubo
    pinatubo
    Have you tried using a different burning software .Other forums - dvdplusrw for example - have indicated problems using Nero.
  4. pgayler
    pgayler
    Dec 11, 2002
    30
    i used dvd-cloner II to burn my copy and that didn't work.
