dvd-r discs
Discussion in 'Blu-ray & DVD Players & Recorders' started by joolz1604, Feb 1, 2005.
  1. joolz1604
    joolz1604
    hi, can anyone suggets a dvd player thats good at playing all brands of dvd-r. quite alot of my discs are sticking or just point blankly refusing to play.
    thanks alot :blush:
  2. slowen
    slowen
    Jan 16, 2005
    208
    16
    I have got a Toshiba SD-330Ewhich I have had for about 2 years and I have never had any playback issues with DVD-R or any other discs. Think they are quite cheap in Richer Sounds :thumbsup:
  3. shodan
    shodan
    Dec 11, 2001
    11,367
    shoeburyness
    +6,148
    On the contary, my SD 330e won't play the DVD-r's I've been burning! (Imation 4.7Gb) Think it played one of them once, but won't play them anymore, but does play some other types...
    But I'm new to all this burning malarky so it could be something I'm doing wrong, although the disc's do play on other machines...
  4. DVD-RAM
    DVD-RAM
    Check the Panasonic model number in my signature, it plays anything I throw at it.
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Pioneer 575 plays anything thrown at it
  6. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    Second, the Pioneer (in fact any Pioneer model).
    And would also suggest NEC.
  7. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,361
    Bristol
    +7,931
    Have to recommend the Pioneer also, but playback does depend on what type of blanks you use, the better the quality they better the playback, if you use budget media then dont be suprised if them freeze/skip.
  8. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    Pioneer 470 / 575 plays everything I've got :)
  9. durandal
    durandal
    On a slightly different note, does anybody know if a tosh 340 will play DVD+R's?
  10. Dean
    Dean
    Jun 20, 2003
    2,871
    London
    +259
    Just thought that I'd add a previous hard to play (Mindhunters) DVD that used to skip now plays completely fine after the 2.09 firmware update that Pioneer sent in the post, so I think my Pioneer DV575 has a 100% record with my DVD collection now! :thumbsup: It also plays all DVD-R's that I've recorded from a Sony RDR-GX3 recorder off Sky so i'm pretty happy.
  11. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    skyworth dvd/divx player from whsmith online £30 delivered
    DK Digital 915 dvd/divx player from ebuyer online £40 + delivery
    play everything I put in em, +r/rw, -r/rw, MP3, WMA, etc
  12. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,361
    Bristol
    +7,931
    I was hoping the firmware update for the Pioneer would fix the problem with the long loading time on Star Wars Episode 2 Region 4 release and even though it has cut down the loading time it still takes about 60 seconds.
