DVD-R Compatibility with Panny E55
Discussion in 'Blu-ray & DVD Players & Recorders' started by InsertNameHere, Jan 3, 2005.
  1. InsertNameHere
    InsertNameHere
    Sep 17, 2003
    264
    London
    +3
    Evening all,
    This is a question for all you Panasonic E55 owners...
    From past experience what are the best DVD-R discs to get for this machine?
    I was going to go ahead and buy some discs based on the Fujifilm03 or RITEKG..05 dye but I don't want to get them and find they skip, don't finalise properly or give me more failures than successes. Any opinions?
    Thanks in advance,
    Alex
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Avoid 8x media as that is where you will run into problems. In addition I would recommend sticking to branded media. The Panasonic E-Shop has Panasonic brand DVD-Rs at under £1 each - unsuprisingly these are great discs for the E55. Also good are TDK Scratchproof DVD-Rs - available here. And Maxell DVD-Rs - here - are also good. To be honest any decent branded DVD-R (Verbatim, Maxell, Pioneer, HP, Sony, Panasonic, TDK) should be fine.
  3. ben223
    ben223
    Hey Ras, nice to see you back!!
    I'm using 8x (Verbatim, TDK and Sony) with no probs.. though I have an E85
  4. ColonelK
    ColonelK
    Jan 7, 2005
    85
    Coventry
    When you say don't use 8x media are you saying that we should use SLOWER media or Faster media?
    I'll be taking delivery of my E65 anytime soon so obviously would like to know ;)
  5. Baj
    Baj
    Aug 26, 2004
    64
    Canterbury
    Avoid Datawrite Yellow (v2) 4x. Many are 8x rejects (in my case 100 out of 125!!).
    The record quality is very poor; Parity Inner Errors and Jitter are very high.
    The recordings will probably be watchable for a month or two.
  6. avio
    avio
    I've used Ritek X4 (g04dye) and verbatim X4 no problems as these are what I use on the computer
  7. andykaz
    andykaz
    Jan 4, 2005
    43
    What happens then?
  8. Baj
    Baj
    Aug 26, 2004
    64
    Canterbury
    The POF (Parity Outer Fail) value (indication of unrecoverable errors) exceeds zero and the disc will not play:
  9. andykaz
    andykaz
    Jan 4, 2005
    43
    Thanks for that, intresting to know :)
