dvd-r chapters
Discussion in 'Blu-ray & DVD Players & Recorders' started by sacd, Aug 15, 2004.
  1. sacd
    sacd
    Feb 19, 2004
    297
    Cardiff
    Can you define where the chapters are on a dvd-r before the disk is finalised? Or are you just stuck with the five minute intervals?
  2. jesmat2003
    jesmat2003
    Mar 8, 2004
    74
    You can set chapter points on the Panasonic E85 machine by:
    1. Setting the High Speed Dubbing option to "Yes".
    2. Recording to the hard drive.
    3. Setting the required chaper points.
    4. High speed dubbing to a DVD-R.
  3. sacd
    sacd
    Feb 19, 2004
    297
    Cardiff
    I have a DMR 55. Before I unpack it i wanted to know about the chapter points. It has no hard drive. However, I do have sky+.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    22,034
    Warwick
    +2,898
    If recording to DVD-R your stuck with the 5min chapter points. If you want to define chapter points on DVD-R you'll need to buy a HDD/DVDR combo.
  5. sacd
    sacd
    Feb 19, 2004
    297
    Cardiff
    Thanks for the reply, does dvd+r work the same way?
  6. Rasczak
    Rasczak
    Apr 3, 2002
    22,034
    Warwick
    +2,898
    No, some DVD+R machines allows you to specify chapters although not precisely - you don't get anything like the Playlist function of -VR. Both types of machine will insert a chapter break when you press pause as well.
