DVD+R and -R version for Panansonic DMR-ES10
Discussion in 'Blu-ray & DVD Players & Recorders' started by hifienthusiast, Sep 11, 2007.
  1. hifienthusiast
    hifienthusiast
    Apr 17, 2004
    24
    3
    According to the user's manual of my Panasonic DMR-ES10, I can use the following blank DVD:
    DVD-R version 2.0 / 4X / Revision 1.0
    DVD-R version 2.X / 8X / Revision 3.0
    DVD+R version 1.0
    DVD+R version 1.1
    DVD+R version 1.2
    When I went to a shop to buy new blank DVD, I could only find DVD+R version 1.3. Can I use this type?
    I also found most blank DVD-R and +R are 16x speed nowadays. Can I use these newer blank DVD?
    What is the difference of the versions and revisions of +R and -R? Thanks.
  2. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    I never use DVD+R on my Panasonics. Some of the unknown branded or even branded 16x discs will NOT be recognised on the earlier machines without a firmware update which can only be done by accredited Panasonic agents (and its chargeable).
    However Panasonic state that their own branded 1~16x DVD-R discs will record on all their machines and having now used around 800 - 900 of these discs without a single failure I guess they are correct.
    http://svp.co.uk/products-solo.php?pid=2777&prepg=2
    The tubs of 100 are currently OOS but they have some 10 Pks (individ jewel cased) which are more expensive to buy.
