DVD+R and DVD-R
Discussion in 'Blu-ray & DVD Players & Recorders' started by garyk, Sep 7, 2005.
  1. garyk
    garyk
    Can anyone tell me what the difference is between DVD+R and DVD-R?
    Someone has told me that DVD-R is mainly used for video and that DVD+R is for data.
    And,
    Someone else has told me the difference between them is one manufacture produces DVD+R and the other produces DVD-R.
    I hope someone can help answer this
  2. mgh0001
    mgh0001
    Sep 5, 2005
    494
    trafford, manchester
    +3
    howdo,
    you can only record in widescreen on a dvd-r, not on a dvd+r
    if that helps
  3. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
  4. JohnboyC
    JohnboyC
    Sep 6, 2005
    S.E
    :lesson: I have created both on pc and they all work on dvd players in usa & here. But I favour DVD-r now because I had a little freezing problem with recent dvd+ discs.You have to go with what your machine will allow. Apparently they are two completely different standards created by different companies.Seems like dvd-r has got the lead on +. I'm sure someone out there has got a far technically superior reply. Sorry its the best I can do now.
  5. KDH
    KDH
    Apr 22, 2004
    89
    ???????????? I have many DVD+R recorded in widescreen
  6. admay
    admay
    Mar 16, 2004
    179
    Cambridge
    +4
    I think what mgh0001 meant was that dvd-r will only record in widescreen whereas dvd+r will record in either widescreen or 4:3 format. Specifically dvd+r will record the flag that defines the format at which it should be played.
    Andrew
  7. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,383
    Somewhere in South Yorkshire
    +5,770
    It's certainly true of the - (dash) format that it will carry the WSS flag (or not) as required. Can't speak for + (plus).
  8. Mark_a
    Mark_a
    May 27, 2005
    3,064
    +612
    Just to be pedantic, what I suspect you meant to say is that both will happily record both 4:3 and 16:9 anamorphic material. The difference being the recording of the bit that tells the DVD player to issue a widescreen signal to the TV on playback, as required.
    Regards
    Mark
  9. alan8477
    alan8477
    Dec 17, 2001
    593
    Pershore
    +11
    The most significant difference is found on DVD recorders. I have used both +R and -R recorders. The most obvious difference is that when I used the + recorder with RW discs, I did not have to finalise in order to play them on other DVD players. This was really useful when you have recorded something that you want to watch in bed. I now (with -RW) have to spend time finalising before I can use the disc in the bedroom.
    I do however, find my current Toshiba XS34 much more reliable than my old Philips 890R. I also find that the discs play on any machine so far, unlike the fussy +RW.
    I should say however, that when either of these formats is copied using my PC drive they are both equally reliable on other players.
    Well, that's my experience any way.
  10. admay
    admay
    Mar 16, 2004
    179
    Cambridge
    +4
    Well put. That's exactly what I meant.
    Andrew
