DVD-R 9.4 GB Double sided Disc Availablility
Discussion in 'Blu-ray & DVD Players & Recorders' started by The G, Apr 20, 2005.
  1. The G
    The G
    I know DVD-RAM discs are available in 9.4GB capacity but does anyone know if DVD-R 9.4GB Double-sided discs are available for my Panasonic DMR-E95H?
    If so where can I get them from? :lesson:
    These would be a particularly useful format to archive to.
    Please note I will only be buying small batches (i.e 10 or 20).
    Any help greatly appreciated.
    G.
  2. maltezer
    maltezer
    Mar 6, 2005
    24
    3
    +4
    The discs are readily available but the drive in the panasonic is only a single layer drive so will only write to single layer discs.
    The 9.4 discs are dual layer.
    Maltezer
  3. Steve N
    Steve N
    Feb 3, 2005
    10,364
    Peterborough
    +1,778
    G,
    These are widely available ( though not in the likes of Curry's etc)
    For good prices try www.pricebuster.org.uk
    Last time I looked they were 4.99 for Maxell, but there is a del. charge.
    Also try www.multiregionmagic.co.uk
    Remember you can archive on DVD-R on your machine but the RAMs are infinitely more flexible
  4. Steve N
    Steve N
    Feb 3, 2005
    10,364
    Peterborough
    +1,778
    G,
    The double sided ones WILL definitely play on your machine, with all due respect to Malteser, I think he is confusing a different format.
    I use the double sided (9.4) all the time and have done ever since I had an E20 . I tend to buy Panny's own brand and have never had a problem.
  5. The G
    The G
    Thanks for those links, but I can only see double-sided DVD-RAM discs NOT double-sided DVD-R discs on those sites. I am ideally looking for DVD-R 9.4Gb to archive to.
    Am I being blind (quite likely)? Or are these not yet affordable/available to the home user?
  6. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    I've never seen a double sided DVD-R. DVD-RAM, yes.
    Mark
  7. Kevo
    Kevo
    Aug 23, 2001
    5,358
    Manchester
    +145
    I've never heard of 'double sided' DVD-Rs either.
    I think an apology to Maltezer is an aorder here :)
  8. Steve N
    Steve N
    Feb 3, 2005
    10,364
    Peterborough
    +1,778
    Malteser and The G
    Please accept my apologies
    My brain was seeing Ram not -R. I assumed Malteser was thinking of double layer discs :suicide:
  9. hammy
    hammy
    Feb 10, 2004
    26
    3
  10. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    I think there may be confusion with double layer and double sided here? The double layer +r's are 8.5GB and DO need a double layer writer. I have one in my PC but I've not seen a 'consumer' one. I think the double sided ones are just like normal DVD-R's but you can flip them.
  11. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    These are not commercially available. I remember reading somewhere about someone glueing two -Rs back to back, using the spindle guide found on labelling kits for accuracy. Everything at your own risk, of course, and there's no guarantee it will work on standalone recorders.
    Double-layer single-sided +R (and soon -R) are of course something completely different.
  12. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    It seems that double sided (yes, double sided, not dual layer) DVD-R does exist - "Hammy" found it. The Verbatim model 94171. And he also gave a link where you can buy them.
    Mark
  13. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    You're right - I didn't look hard enough. Apologies to Hammy, and yourself... :suicide:
    It was also baffling that the retail site was offering marker pens for use on these discs!
  14. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    I love it... this gave me a good laugh! :D
  15. dgp
    dgp
    Mar 12, 2003
    11
