dvd/ pwd6 prob HELP PLEASE!!!!!!!!
Discussion in 'Plasma TVs Forum' started by NAUTILUS, Feb 27, 2005.
  1. NAUTILUS
    NAUTILUS
    hi
    just got me pwd6bx..lovely pic apart from region 1 dvd,s they get like a flashing pic , region 2 perfect , the dvd as been modded to play r1 disks, if i put them on my 42 rear projection no probs!!
    the player is sony dvd dav sc8 please help as been trying for hours as well
    as putting the panny on the wall!!
    terminal board is scart (brand new with plasma)
    many thx
    nautilus
  2. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    guessing here...............................could it be something to do with progressive scan................................is it currenlty switched on or off?
    cheers,tam
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It might be that the panasonic scart board doesn't like NTSC signals? You certainly would have no problems on component video, doesn't the Davs 8 have this? Or is tam right, and is it prog scan on NTSC only, and therefore is trying to output prog scan on scart and that's what the Panny doesn't like. Get into the menu and turn it off, or is it a switch on the back on that one?
  4. NAUTILUS
    NAUTILUS
    thx for reply lads
    how do i get to prog scan on the tv? as i have not seen it in the menu setup
    once again thx
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    On the DVD, not the screen. The screen tries to autosense whatever is sent, we think this is the prob. You need to set the Davs to interlaced.
  6. NAUTILUS
    NAUTILUS
    hi mate
    i have a 42 in rear projection as well and had no probs with reg 1 dvds on that for over a year now..
  7. NAUTILUS
    NAUTILUS
    thx for reply lads
    got it sorted changed the settings on dvd to rgb...
    cheers
