dvd/ps2/freeview straight to plasma or a/v?
Discussion in 'Plasma TVs Forum' started by ultraman, Jan 11, 2004.
  1. ultraman
    ultraman
    i get the impression most people here plug their respective video inputs from DVD/freeview/PS2 straight into the plasma screen and audio to the a/v receiver. Why can't you plug it all (video and audio) thru to a a/v receiver and hopefully try to control the tv from there?
    is there a loss in picture quality by way of the a/v receiver, even if its rgb to the a/v, then rgb from a/v to plasma?
    this is of particular interest to me since i'm considering buying the Sony PFM 42v1, on which a dvi and dsub is standard and a rgb board is optional (and has only 1 rgb input).
    any help would be appreciated.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    can use an Iscan or an amp with video switching, most mid>high amps will do S-video and component, very few do scart what sort of budget do have for an amp as if sub £200 pio 301 is great, if over £600 the Tamaha RV1400, Denon 3803 and HKAVR4550/5550 will al do component as will many others.
  3. ultraman
    ultraman
    i have in mind either the sony 790, marantz 5400, denon ag10, teac or yamaha of similar caliber. ie looking to spend around 200-300 for an amp.
    perhaps its just my impression from reading all the plasma posts that everyone is plugging their rgb cables from the dvd players straight into thier plasma and not routing it via the amp.
  4. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    The quality of the picture on the plasma is very dependent on the source quality.
    For this reason, all of my sources are RGB or Component. Quite simply, you won't find an amp that switches RGB or Component video signals for £300.
    The most cost effective solution maintaining optimal quality is to go direct. Use a JS Tech box and cascade your scarts if you can to give you some automatic switching.
    Hope this helps,
    James
  5. nealgs
    nealgs
    Use our Yamaha RXV1000RDS receiver to do switching via component of sky/dvd (althought sky box and DVD player are daisychained via scart, then fed to a JSTech RGB2YUV convert first)
    this then goes amp, then amp to plasma.
    also use amp to switch Xbox feed (standard composite at the moment) - must say that picture from xbox composite isn't to bad at all - not perfect, ut know were near as bad as i'd thought it would be.
    Gary
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Actually you will for £160, Pioneeer VCXS301 will switch 3 RGB scarts to a screen, not sure what the quality loss would be if any but it is possible.
  7. ultraman
    ultraman
    Gary thanks for the input
    any chance of switching the inputs (direct vs indirect) to see if u can spot any quality differences?
    Horny dragon thanks too!
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    THe pioneer 301 may be a little light to partner a 42" plasma but i think th 501 its bigger brother does the same thing with scart so worth a good look, £800 Yamaha 1400 will do YUV+S-video switching and up conversion but is a lot more amp for your money!
  9. ultraman
    ultraman
    JamesTapp, after a bit more research i see what you mean. I am now considering spending a bit more to get something like the Sony STR 2000 at around £380 for more connection options.
    most a/v receivers seem to pack a lot of composite analogue connections rather than quality RGB or svideo.
    i think i have a better idea of what i want from my amp, which is
    2/3x rgb inputs.
    2 s video inputs.
    3 optical inputs
    Other than the sony, are there any other options i should be looking at?
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    You wont get many with RGB but you will with component at £300 + plenty of yamahas have YUV+ S-video switching Denon, HK, and so on also look at PIO 812,912 no YUV IIRC
  11. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    I would agree with Horny, if you want something that is user friendly and switches audio as well as video then look for an amp with YUV (Component) inputs and outputs. But this doesn't help your original question of going in on the VGA input...
    If you can daisychain your Scarts, I would do so. It is the way I have my DVD, Cable box, TIVO and PS2 into a single Component input - and the quality is fine.
    If you daisychained your Scarts you could then use the JSTech RGB2VGA to go into your Plasma DSub - although check its compatibility first - and that you get all of the screen settings you need.
    Not heard much about the latest Sony offerings for amplifiers - although I believe that Pioneer are leading the pack - Harman Kardon I have heard and was impressed with, but their styling is not to everyones taste.
    Good luck.
    James
