dvd profiler
Discussion in 'Movie Forum' started by mr ooops, Nov 2, 2004.
  1. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    Hardwicke and Wotton
    +349
    Hi all,
    ive been using this (like most of you here) to list my dvds, but i have a slight problem, on my pc it states 258 in my collection, but when i view online some are mssing for some reason?
    any suggestions
    also sorry if wrong room, it seemed to be the most fitting
    cheers
    Jason
  2. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,043
    Babel Sensurround
    +207
    You have to upload them from your collection :)
    Adrenochrome.
  3. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    +349
    I have :) but makes no difference :(
  4. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    +349
    it looks like all the ones with 18 cert are missing from my online profile? for example 1 and 2 and 11 and 12 in my collection are 18 certificates and are missing......... any ideas?
    edit
    problem solved, went to there website and had to tick the adult content box :)
  5. bluedoo
    bluedoo
    Dec 13, 2002
    405
    +15
    if you go into tools/options/parental control
    there is a box for hide adult titles in online listing
    make sure this is unchecked
    should be ok after that
