DVD Profiler - WOW!
Discussion in 'Movie Forum' started by Techno Freak, Dec 13, 2003.
  1. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    Just downloaded DVD profiler - what can I say, absolutely fantastic.
    Can anybody tell me how to get my link to work in the signiture?
    Here is my list:- ( you will have to cut and paste into your browser )
    http://www.dvdprofiler.com/mycollection.asp?alias=techno freak
    Any help on hyperlinking this on my sig strip would be appreciated.
    Thanks.
  2. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    As you can see, I have sussed out the signiture url problem.
    Just click on My Collection to see my DVD's.
    go here www.dvdprofiler.com for the free sofware - it's brilliant.
  3. paul1672
    paul1672
    Jul 31, 2003
    2,553
    71
    norfolk
    +37
    anyone know how to change the link to something like "my collection"??
  4. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    Here you go.
    My Collection
    Which you will need to insert as
    [ABC=http://www.dvdprofiler.com/mycollection.asp?alias=paul1672]My Collection[/ABC]
    Replace ABC with URL in both locations
  5. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    "Private Collection
    This user has chosen to keep their online collection private.
    If you are this user and would like to change this option, please visit the My Collection Options page and adjust the Visibility setting. "
    :rolleyes: :D
  6. andy76
    andy76
    Just tried out DVD Profiler too!
    It really is a good piece of software isn't it?
    Guess I will be spending a couple evenings adding everything now!
    Andrew
  7. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    If anyone has a DVD collection that will end up leaving your fingers sore (from typing in all the UPC codes) then I can highly recommend the CueCat barcode scanner from www.mavin.com. Supported directly by DVD Profiler and works a treat.
    The best bit is it's only about £12.
    http://mavin.com/computermice.html
  8. soulbrother
    soulbrother
    Hi,i just downloaded this aswell but i dont know how to get it on my signature?so people can view my collection.
  9. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    Look at my post above and just include it in your sig but replace the username after the = with your own
  10. paul1672
    paul1672
    Jul 31, 2003
    2,553
    71
    norfolk
    +37
    very much apreciated.
    many thanks messiah mate.
  11. graham.myers
    graham.myers
    Mar 11, 2003
    6,220
    Leeds
    +932
    Profiler is indeed v. good. I've been using it for over a year. I also registered so I get hold of the beta versions. Wish they'd get thier act together to release the Pocket PC version tho
  12. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    I was just thinking about a pocket PC version also. It would be ideal as I use my PDA as a remote, having a decent version of your DVD lists on it would be supberb.
    A CD version would be good aswell.
  13. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    I have changed my settings now, Id did'nt realise you could not see my collection, I have been back on and made it public - thanks for the warning.
  14. soulbrother
    soulbrother
    Hi Messiah.thanks for the info,but still cant work out how to do it,do you have to add a signature to your profile for it to appear on any postsyou submit?
  15. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    You've been busy. You've input 650 discs in less than 24 hours. Wow :eek: Well done.
    Look again at my post above. Simply change the ABC to URL in both places then put your DVD Profiler Username after the = sign. Then copy the whole lot, including the open and closing square brackets and put that in your sig. It really is very simple if you follow my instructions above.
    Like this
    My Collection
    [ABC=http://www.dvdprofiler.com/mycollection.asp?alias=michael]My Collection[/ABC]
    And yes you will need to add it in your profile signature.
  16. hulkhead
    hulkhead
    Jul 2, 2002
    670
    Kent
    +11
    has anyone else noticed this - I have uploaded my dvd collection (see link below) but the online version has missing films from the version on my pc. Any ideas?
  17. graham.myers
    graham.myers
    Mar 11, 2003
    6,220
    Leeds
    +932
    are they 18 certs and have you got hide adult material switched on?
  18. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    Yep. You will find your profile is set not to display titles with Adult content, 18 cert (or ones it thinks has Adult content - language, violence, sex scenes, etc). Simply set your online profile to display all titles and the missing ones will re-appear :)
  19. hulkhead
    hulkhead
    Jul 2, 2002
    670
    Kent
    +11
    cheers guys I'll check my settings. it has missed out some horror movies.
  20. soulbrother
    soulbrother
    Hi Messiah,finally maneged to get my link sorted.Thanks once again .Top man.All i have to do now is enter my 190 strong collection.
  21. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    Nice one :)
  22. Dave H
    Dave H
    Aug 20, 2000
    4,373
    Lots of different places!
    +145
    Am I missing the point here ? what is it used for, is it just so other people can see what films you have ?
    Dave.
  23. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    That's all it's for. DVD Profiler is ideal to enable you to catalogue all your films and share that list with family and friends. It can handle loans etc if you do that. Putting it in your sig is, well, who knows what for. Don't really want the world to see the value of my collection.
  24. Ghidorah
    Ghidorah
    Oct 16, 2002
    134
    19
    Bristol
    Hello.
    Bit thick here but what is your URL ?
  25. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    ??? :confused: A URL is a link to a page or site on the web. The URL's being referred to above are the links to the individual's DVD listing which is held on the DVD Profiler site.
  26. mackemansj1
    mackemansj1
    How do u add indiana jones set? still cant sort out the link ????
  27. Ghidorah
    Ghidorah
    Oct 16, 2002
    134
    19
    Bristol
    Ahhhhhhhhhh, I see said the blindman
    Think i have it now.
    You mean put the letters URL instead of the letters ABC at either end.
  28. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    :clap: :smashin: Well done.
  29. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    OK, let's try a different way for those that are still link challenged ;)
    Use the text below in your signature to show your DVD Profiler site as a link. Remove the 2 x spaces between the first U and R and R and L so it looks like URL not U R L. Then simply insert your DVD Profiler username in place of username (after the = sign) and away you go.
    [U R L=http://www.dvdprofiler.com/mycollection.asp?alias=username]My Collection[/URL]
  30. Ghidorah
    Ghidorah
    Oct 16, 2002
    134
    19
    Bristol
    :rotfl: YIPPPPPIEEEEEEEEE
    ITS ALIVE ITS, ALIVE HA HA HA HA
    Job done
    ( Must go and have tea this is getting to me )
