DVD Profiler question
Discussion in 'Movie Forum' started by ollie501, Oct 14, 2003.
  1. ollie501
    ollie501
    Jul 14, 2003
    1,004
    Dorset, UK
    +25
    Been using DVD profiler for about a month or so, and on the whole think it's a cracking bit of software.
    The only thing I haven't managed to find (if it is there), is the ability to sort by running time.
    I know it has pretty advanced sort filters, but would find this one useful for helping choose films in the evening!
    Ollie
  2. Lux
    Lux
    Nov 10, 2002
    759
    Luxembourg
    I do not believe that that feature is present. at least I haven't found it.
  3. keiths
    keiths
    Nov 19, 2002
    168
    Derbyshire, UK
    I'm pretty sure that you can't do it directly, but you can click on File/Export Profile Database, select the Title and Running Time Columns and save as a CSV file. Then open the CSV file in Excel (or Lotus 1-2-3 or OpenOffice spreadsheet etc) and sort on the Running Time column. Not pretty, but it works!
