DVD Profiler Q
Discussion in 'Movie Forum' started by rosemanbridge, Jul 14, 2003.
  1. rosemanbridge
    rosemanbridge
    May 24, 2002
    257
    Is there a site which lists the UPC numbers for DVD's? I've got the region 3 ET and it doesn't have a proper number. Also, is it possible to print out the Profiler list of DVD's in my collection? Thanks.
  2. rosemanbridge
    rosemanbridge
    May 24, 2002
    257
    Or can someone at least post the number for ET (any region will be fine) so I can add it. Thanks.
  3. daftmole
    daftmole
    Oct 6, 2002
    2,200
    kent
    +398
    Why don't you enter the title by name, instead of UPC. If you enter the name, you will get a list of all the different profiles and regions, you can then find the appropriate one.
    Hope that helps.
  4. Confucius
    Confucius
    Feb 1, 2001
    2,148
    Oxford
    +132
    One can select the region in the title entry section too.
  5. rosemanbridge
    rosemanbridge
    May 24, 2002
    257
    Nope, tried all that, still no sign of ET !
  6. Confucius
    Confucius
    Feb 1, 2001
    2,148
    Oxford
    +132
    It is in the region 3 database if you try to add by name. It gives a choice of two, the Korean or Hong Kong 'version'.
  7. Confucius
    Confucius
    Feb 1, 2001
    2,148
    Oxford
    +132
    Hint: How are you spelling ET?
  8. daftmole
    daftmole
    Oct 6, 2002
    2,200
    kent
    +398
    Try this UPC, I believe it's the correct version:
    893031017668
    If not, then as confucius says, select region 3 and type 'E.T.' in the database search, there are two region 3 entries.
  9. rosemanbridge
    rosemanbridge
    May 24, 2002
    257
    Thanks Guys. I was putting in "ET" or "Extra Terrestrial" and not "E.T." Got it now, the end of a somewhat boring thread I'm afraid!
