Dvd Profiler Help Needed
Discussion in 'Blu-ray & DVD discs' started by s1hastie, Sep 11, 2005.
  1. s1hastie
    s1hastie
    Apr 10, 2005
    2,423
    48
    +38
    Hello hopefuly other people use this software as well to catalogue their dvd's. Just need some help with something. I am going through adding my collection no problem but in some cases I have more than one version of a dvd.
    For example Tomorrow never dies, I have the region 2 and the region 1. I have added the region2 but when I go to add the region 1 it says "Tomorrow never dies is already part of your collection"
    Is there anyway round this.
    thanks in advance.
  2. CeeGee
    CeeGee
    Aug 28, 2004
    92
    Weybridge, Surrey
    It could depend on how you are trying to enter the new version. I use the EAN number, but if you use the "add by title" make sure you select the correct region version. It should then work. (It does for me)
  3. s1hastie
    s1hastie
    Apr 10, 2005
    2,423
    48
    +38
    Tried both of those. Didn't work. Have got it sorted though by putting the disc in and adding by disc id. This seems to work as it has added it ok and i now have 2 tomorrow never dies special editions in my collection.
