DVD Profiler doesn't recognise Wrath of Khan
Discussion in 'Movie Forum' started by Lex, Mar 9, 2003.
  1. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Hi all,
    I just tried to input Star Trek II: The Wrath of Khan - Director's Edition (R2) into DVD Profiler, but it doesn't recognise the UPN, and it isn't listed under the names - seems strange for such a mainstream DVD - especially as it has been out for several months! :confused:
    Even more mysteriously Star Trek III worked fine!
    Anyone else?
    Also - No pic yet for Angel Series Three :confused:
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,417
    2
    In a secret location with Jennifer Lawrence
    +9,112
    Strange one that Lex.
    Try 5014437820136.
    Worked for me fine.
    Or try the EAN which is 014437-820136
    Greg
  3. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Thanks Greg - I will give that a go (I'm on a different pc at the moment). It is strange though - I wonder if its because it is the cardboard case - is yours cardboard or the plastic amaray?
  4. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    session 9 R2 still doesn't work on mine, now after connecting profiler is skipping all the updates.... annoyed!:mad:
  5. Greg Hook
    Greg Hook
    Nov 25, 2001
    22,417
    2
    +9,112
    Mine is the plastic case inside the cardboard case.
  6. dfield2000
    dfield2000
    Jul 16, 2002
    957
    Cardiff
    +5
    I can't remember which DVD it was now, but I had one with a EAN code on the cardboard case that was not recognised, but it had a different code on the actual plastic box which was recognised. Off the top of my head it might have been Gangs of New York, but I might be wrong.
    Don't HMV have their own special packaging for certain releases ? These must not be as common as the standard releases so it's less likely that people will submit and register these codes with DVD Profiler.
  7. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Yeah this thread is several months old now... DVDProfiler now recognises the code off of the cardboard case and the plastic case ;)
  8. graham.myers
    graham.myers
    Mar 11, 2003
    6,220
    Leeds
    +931
    should it not be closed then?
  9. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    :confused: If I had closed it then you wouldn't have been able to reply ;) :D
  10. dfield2000
    dfield2000
    Jul 16, 2002
    957
    Cardiff
    +5
    I was just doing a search on 'Wrath of Khan' to before I posted a new thread on the subject and this one turned up in the search results. I didn't check how old it was first - Sorry.
  11. Family Guy
    Family Guy
    Treasure Planet R2 dosen't register either - and when you try and enter it by name, it still dosent recognise it...:confused:
  12. derekduvalle
    derekduvalle
    I also had trouble with "Wrath of Khan" & "Search for Spock" using the code on the back of the cardboard sleeve.
    Sometime DVD profiler does not correctly "Refresh Profiles".
    To get this to work click on:
    Tools;
    Options;
    Utilities,
    and then on "REPAIR DVD PROFILER DATABASE" and "RESET DOWNLOAD TIMESTAMPS"
    This will enable a complete relisting of "Profiles".
    All those discs you know should be on profiler but you cant get should now work.
    I am using Version 2.1, build 616, not sure if the above applies to other versions.
