DVD Printer
Discussion in 'Blu-ray & DVD Players & Recorders' started by davecabezo, Oct 23, 2005.
  1. davecabezo
    davecabezo
    Jan 15, 2005
    84
    9
    Hi M8s,
    Not sure if this is the correct forum but no doubt it will be moved if not.
    I want a decent printer which will also print to DVDs. I looked had the Epson r200 but the cost of replacement cartridges was prohibitive so I started to refill the cartridges. It was OK for a short while, but then the printer started to act up, the paper would not load correctly unless I switched off then on again etc. etc. Then the printer would not print anything, as soon as it was switched on it went through it's routine then both the print & paper lights would come on and the printer hung. It's probably not worth repairing as they are only £65 new, about the same price as a full set of replacement cartridges!!!!
    So any ideas or suggestions for a replacement.
    Regards,
    Dave :lease:
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
