DVD players with DVI connectivity
Discussion in 'Blu-ray & DVD Players & Recorders' started by admerial, Aug 5, 2004.
  1. admerial
    admerial
    Does anyone know of a DVD player that has a DVI input or output. I already know about the Sony STRDA9000ES, but I was wondering if anyone knew of anyother players with a DVI capability.
  2. SamirP
    SamirP
    Apr 28, 2003
    1,303
    South Of The River
    +38
    Samsung 935 dvi output
    Yamakawa 365 dvi output
    Momitsu 880 dvi output
    Bravo D1 dvi output
    Marantz 8400 dvi output
    Pioneer 668 & 868 hdmi
    Plus there area number of dvi/hdmi players due out this year, from the likes of Panny, Denon, Sony, Tosh
  3. scoooby
    scoooby
    Mar 22, 2004
    104
    Try searching you lazy plum.
  4. admerial
    admerial
    thanks a bunch man.
  5. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,244
    2
    +3,766
    Also the Marantz DV12. The 8400 is now technically discontinued to be replaced by the 7500 and the 9500- both HDMI capable :).
  6. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    And also Denon A11 DVI output !
  7. Apnomis
    Apnomis
    Jul 4, 2003
    393
    Cheshire, UK
    +25
    Look at the thread about the new Denon range: http://www.avforums.com/forums/showthread.php?t=144609
    All their new range launched end of August/September will have DVI output, along with a load of other features to appeal to Plasma/LCD owners, like 1080i and 720p scaling. Even their "budget" £200 model supports these features. Plus the ones linked to in the thread are multi-region out of the box, and they look pretty nifty too...
  8. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Come on guys - you've forgotten the Arcam DV79, which has an HDMI output :)
    John Dawson (Arcam)
  9. Mister M
    Mister M
    John Dawson i just bought a dv79 i am waiting for it.:) is it already on its way to holland:)
    It will run next to my avc a1se for now but i am going for a total arcam set.
    the av8 and p7 will it stick around for sometime or is a replacement on it s way.
    Andre a new arcam customer.
  10. Jackass
    Jackass
    Jan 9, 2003
    3,469
    +858
    John (Arcam)
    I see that Denon are advertising there new 3910 player.
    On the 3910 description on Denons USA website it mentions:
    'HDMI Multi-Channel Audio Compatible output'
    I thought this wasn't coming out till next year and we were stuck with only 2channel audio over HDMI for now ????????
    Has the Arcam 79 got a 'HDMI Multi-Channel Audio Compatible output' ?
    Regards,
    Steve
  11. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Jackass - it depends what Denon means as all HDMI transmitters support Dolby Digital and DTS streams. The HDMI chips that support discrete multichannel audio (as in DVD-A) were not available at the time of the DV79's release so not surprisingly it doesn't support this. However the DV79 does output DVD-A as analogue, to a very high standard, and includes proper bass management etc.
    Mister M - it is always difficult to comment in public on future product plans as such things are commercially very sensitive. However I think you can buy an AV8/P7 with confidence :)
    HTH guys,
    John Dawson (Arcam)
  12. Mister M
    Mister M
    thx for the comment john dawson
    proberly next month i order the av8 p7 combination.
  13. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,708
    7
    2
    167
    Birmingham, UK
    +10,591
    Scoooby gets a week ban.
  14. Barend
    Barend
    Apr 12, 2004
    804
    +9
    What dvi pal resolutions does the DV79 support?
    My Pan. TH42-PWD6EX only accepts 576p @ 50 Hz...
    If it should work I'll probably buy a DV79 and flog my Pio DV868avi which only works for ntsc, which means Il have to watch all 2 of my ntsc discs again again because the quality is so fantastic...
    Barend
  15. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    DVI resolutions are 576/50 and 480/60 progressive in RGB. So it should work.
    John Dawson (Arcam)
