DVD Players compatible with DVD RAM?
Discussion in 'Blu-ray & DVD Players & Recorders' started by hollie.weimeran, Aug 12, 2004.
  1. hollie.weimeran
    hollie.weimeran
    1st question - are Panasonic the only manufacturer of DVD Players compatible with DVD RAM?
    2nd question - Whats the Panny S27 like?
    I'm not after an all singing/dancing player, it's for a bedroom but must be able to play back DVD RAM as I have a Panny recorder - any reccomendations welcomed. :) :lease:
  2. Londondecca
    Londondecca
    Dec 21, 2003
    2,105
    +108
    The S75 does and it is a great machine
  3. MagicBoy
    MagicBoy
    Sep 19, 2003
    308
    +21
    The S35 and the new S27 and S47 do also.
    Point to note - you need to remove the disk from the caddy in these players - they accept bare disk only.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    S47 or 75, 27 is a bit too bare.
  5. hollie.weimeran
    hollie.weimeran
    Thanks for that - my son already has an S35 which is great - is the s27 it's successor?
