dvd player
Discussion in 'Blu-ray & DVD Players & Recorders' started by psalliss, Jun 19, 2005.
  1. psalliss
    psalliss
    Aug 27, 2003
    553
    Heysham
    +9
    could someone reccomend a few players too me that have either composite or dvi out or both please as ive just bought a sagam hd45 and would like to get a new player as current player only has a scart output. looking upto £500 if neccesary but want spend around £250 cheers
    i require multi region and wanting a player that produces a good rich quality picture
    cheers
  2. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +219
    Every player ever released has composite out. I take it you mean component output.
    However if your display is capable of taking a digital connection you are better off with a digital connection rather than component. Component is analogue and does not compare to a digital connection unless there is some sort of hardware mismatch or problem using digital like macro blocking.
  3. psalliss
    psalliss
    Aug 27, 2003
    553
    Heysham
    +9
    your completely right mate i did mean component out.
  4. psalliss
    psalliss
    Aug 27, 2003
    553
    Heysham
    +9
    has anyone got any suggestions what about the denon 2910 or 3910
  5. Mark_a
    Mark_a
    May 27, 2005
    2,890
    +495
    I just bought a multi-region Panasonic S97 from Richer Sounds for £160, meant to have retailed for about £300 when it first came out. It's got progressive PAL and NTSC component and HDMI output, and will scale non hi-def feeds upto your display's native resolution. Looks pretty damn fine on my Tosh 52" I can tell you. Well pleased for the outlay.
    Regards
    Mark
  6. psalliss
    psalliss
    Aug 27, 2003
    553
    Heysham
    +9
    cheers mate anyone else on the denons please
