dvd player with mic
Discussion in 'Blu-ray & DVD Players & Recorders' started by corriefan, Jan 6, 2004.
  1. corriefan
    corriefan
    Jan 5, 2004
    3
    would appreciate any recommendations for cheap dvd player
    with mic input to use for karaoke dvds
    tia
    corriefan
  2. kbfern
    kbfern
    Aug 17, 2002
    17,799
    Wolverhampton
    +5,960
    Try a Ronin P80H from dabs at £49.00 + £4 carriage.An absolute steal of a machine.Does multiregion,dts,component,progressive scan.5.1 output and of course has 2 mic inputs for karaoke.
  3. corriefan
    corriefan
    Jan 5, 2004
    3
    thanks for the advice keith much appreciated
  4. revo
    revo
    Jan 10, 2004
    38
    9
    whatever you buy make sure your karaoke machine has adjustable echo control (essential for the karaoke sound) and cd-g capability - they are faster to start than karaoke DVDs and there is a much better CD selection. e.g. sunfly.
    Clive
    try looking at www.emkaraoke.co.uk
  5. revo
    revo
    Jan 10, 2004
    38
    9
    oh and p.s. you won't be suprised to hear that the Mic is the bit that makes you sound like a superstar (ahem), get the best quality you can afford from the likes of shure sm58 or beyer x58.. (my DJ and muscian friends highly recommend them as they are pratically indesctructable - just right for parties!) I got mine from www.digitalvillage.co.uk, they all sometimes have some b-stock bargains.
    C.
