DVD Player with dual Scart &Component
Discussion in 'Blu-ray & DVD Players & Recorders' started by Lyricman, Apr 8, 2005.
  1. Lyricman
    Lyricman
    May 19, 2004
    243
    UK
    +21
    I was looking to get a DVD player that I can connect the Sky Box to using RGB and have this to convert the signal to Component for My Toshiba MT200 Projector.
    Alternatively do I have to buy an RGB to Component Converter.
  2. Ged
    Ged
    Apr 29, 2002
    943
    +24
    This is only a guess...
    If you used a DVD recorder, could that work?
    Maybe post in the recorder forum asking whether the RGB Sky in can be up converted to component.
    I use an RGB to plasma converter at the end of Sky-> DVD-R-> Humax set up, you could change it to RGB to component.
