DVD player with component out
Discussion in 'Blu-ray & DVD Players & Recorders' started by chriscarthy, Aug 1, 2002.
  1. chriscarthy
    chriscarthy
    Has anyone got the philips dvd q40. can they give me any advice on the machine and whether it is worth extra money for multi region? Please help as i think this palyer is the one for me!
    Thanks:blush:
  2. NeoBlade
    NeoBlade
    As far as I know, you can make the DVD player multi-region via a remote hack... But you have to use a One-For-All 6 remote or a PDA. The Q40 is quite nice but there are better players around...
  3. chriscarthy
    chriscarthy
    You say better players, which players are better than the q40 for under £180? Tell me and ill have one! oh and by the way, dont say the Toshiba sd220! cos i know this is a good player but doesnt decode dolby digital
    thanks for the info
  4. NeoBlade
    NeoBlade
    If decoding dolby digital was really an issue, you would have spent some cash on a decent AV receiver... It would give a much better performance than any built in encoder thats for sure. Hell you can even buy some highly rated Yamaha receivers now for £200 new.
    Anyways, I'm fairly sure that it can be remote hacked... Have a look at this place mate - http://www.totaldvd.net/features/hacks.php or www.dvd.reviewer.co.uk
    I've just ordered the Philips Q50 and I hope it arrives without any problems...
