DVD player to upscale via component?
Discussion in 'Blu-ray & DVD Players & Recorders' started by reklor, Jul 25, 2005.
  1. reklor
    reklor
    Nov 24, 2004
    5,027
    Huntingdon
    +193
    Hi everyone. Im not sure if this has been covered before but im after a DVD player that can upscale 720p/1080i via component video. My budget is <£200........has anyone got any suggestions on which player to go for?
    Thank you :)
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,129
    Rainham Essex
    +2,392
    Take a look at the Samsung HD-950 or HD-850 (or the older 745/845) DVD players as they will upconvert via component once the multiregion hack has been entered via the remote.
    Mark.
  3. reklor
    reklor
    Nov 24, 2004
    5,027
    Huntingdon
    +193
    Ok cheers mark. Have I got any other options or is the samsung the only one?
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Why do you want to upscale component?...PJ :)
  5. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    You could also consider the Momitsu V880 it upscales via DVI as well as component.Multi-region via menu option and PAL-NTSC-PAL conversion.
    Should be able to find it for about 180quid.
    Full spec: www.momitsu.com
    Have just picked up one 2nd hand for 27quid with no remote - will be posting images in the members home cinema setup forum when RC arrives.
