DVD player to suit TW10H
Mike-M
I have just got a TW10H which I am very pleased with. The trouble is that my DVD palyer (tosh 340) has started to play up, Skipping and jumping scenes and it looks like I will have to replace it.. Before I do I was wondering if anyone can suggest something that will display well using the PJ. Budget upto £200.
M
maxiboy
I use a Pioneer 575a through component and am very pleased with it. My advice is that it isn't really worth spending more than this, just make sure that you get some fairly decent leads and calibrate properely.
