DVD Player to suit BenQ PE5120 Proejctor
Discussion in 'Blu-ray & DVD Players & Recorders' started by benjiP, Jul 18, 2005.
  1. benjiP
    benjiP
    Hi All.
    I'm about to buy this DLP projector for watching films on, so will also need a DVD player. Obviously, I'm not looking to spend too much, so around about £100 would be good.
    What do you recommend?
    Have seen a new KiSS model - the DP-1100 (http://www.kiss-technology.com/?p=1100&v=users) which 'upscales' - would this be a good thing??
    Thanks in advance.
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    There's potentially no advantage, infact there may be downsides, to upscaling a Standard Def source only to have the Standard Def display device scale it back down again.
    I can recommend the Pioneer 575 for around that price, connect via component leads...PJ :)
  3. benjiP
    benjiP
  4. Stathis
    Stathis
    BenjiP, you need a player with a digital DVI output to get the most out of the lovely 5120. I connect it through the DVI exit of my PC graphics card and the picture with Zoom Player and/or WinDVD is stunning (considering the cost of the PJ)!
    Wait until the upcomming KISS 600 which will carry a digital output appears or go for the OPPO/BBK, Panasonic s97 players.
  5. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
  6. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Though using a DVI connection will obviate the need for d to a conversions there's no guarantee it will be better then a decent component DVD player...PJ :)
  7. benjiP
    benjiP
    So what would be the best connection to use for the PE5120 then?
  8. sconie
    sconie
    Aug 2, 2004
    285
    Glasgow
    +13
    I have just bought one of these Pj's and from what I have read I will stick with component for now, I have been using a cheap amw pa85 home cinema set up with my old X1 and going by the reccs on here I will probably buy the Pioneer Dv575 player, I will use my old surround system until I have spare dosh to upgrade.
    :thumbsup:
