DVD Player to go with Philips 32PF9986
Discussion in 'Philips TVs Forum' started by CarnalSins, Nov 12, 2004.
Tags:
  1. CarnalSins
    CarnalSins
    I just ordered the Philips 32PF9986 and I'm looking for a good DVD Player to buy. My budget is around 500 Euros.
    The one I have spotted is Philips DVP900SA. From what I read Philips used it in compination with the 9986 in the latest shows.
    Anyone knows if it's actually any good?
    **** Newbie question : the 900SA has an HDMI output while the 9986 has a DVI input. What kind of cable am I going to need ? Does anyone knows if it's included in the package of the DVD or the TV or do I need to buy it ?
    Thanks in advance
  2. Mr109
    Mr109
    Nov 4, 2004
    48
    I am thinking of the same TV, I was going to get the Samsung 945 to go with it. It has DVI and is cheaper.
    Regards
    Al
  3. Alan D
    Alan D
    I am so far quite happy with my Denon 1910. I know it gets slated daily on here - but I have not had any obvious problems running it with the 37PF9986 via DVI at all settings 576p, 720p and 1080i. (using a £40 Supra DVI-DVI cable) I did consider the Philips 900SA, but I was told it has been put back to January. The Samsung is much discussed, but no-one seems to have one (and there are unanswered questions about its performance at 720p and 1080i). So the Denon seemed the best bet.
