dvd player to go with Panny PTAE300
Discussion in 'Blu-ray & DVD Players & Recorders' started by LITTLEBRITAIN, Dec 9, 2004.
  1. LITTLEBRITAIN
    LITTLEBRITAIN
    Nov 28, 2004
    289
    19
    Greater Manchester
    hey all, i currently have a ptae300 pj and am looking for a dvd player/HTPC that would get the best out of my pj.
    any recomendations? ie scalling etc
  2. paulfoley
    paulfoley
    Sep 17, 2003
    3,507
    Hants
    +112
    a Sony 930. It loved my AE300, it used to plug its component leads in the back & send it into Progressive ecstacy.
    :thumbsup:
    Seriously they go very well together.
  3. LITTLEBRITAIN
    LITTLEBRITAIN
    Nov 28, 2004
    289
    19
    Greater Manchester
    hi mate, thanks for your reply. iv got a dvi cable in place and was thinking of a denon dvd2910 or 3910 VS home cinema p.c
    was wondering about resolution etc
  4. paulfoley
    paulfoley
    Sep 17, 2003
    3,507
    Hants
    +112
    Dont think thats going to work. I upgraded my Ae300 to the Ae500 so that I'd have a HDCP DVI Socket. I use this with a Denon 1910.
    You will probably have to go with a HCPC or a Samsung that has been hacked ?
    :rolleyes:
  5. LITTLEBRITAIN
    LITTLEBRITAIN
    Nov 28, 2004
    289
    19
    Greater Manchester
    thats what iv been trying to find out. thinks thats answerd my question. im guessing the ae300 will do 480p with the dvi input? that should be better than component shudnt it? thanks mate
  6. paulfoley
    paulfoley
    Sep 17, 2003
    3,507
    Hants
    +112
    Sure will !
    :thumbsup:
  7. LITTLEBRITAIN
    LITTLEBRITAIN
    Nov 28, 2004
    289
    19
    Greater Manchester
    thanks mate, iv arranged to borrow a 3910 tomorrow nite so ill give it a go
