DVD player to AV amp - Coaxial connection
Discussion in 'AV Receivers & Amplifiers' started by MJeeves, Sep 20, 2004.
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    I am getting an coaxial interconnect for between my DVD player and my AV amp and have heard good things about the VAN DEN HUL "THE FIRST - METAL SCREEN".
    According the Van Den Hul http://www.vandenhul.com/cable/frst-u.htm and the shop I go to says that the VDH "THE FIRST - Metal Screen" is 75 Ohm, and the distributor also said it was but... they would wouldn't they? Here is what it says on the product itself:
    "Ideal for... SPDIF digital audio interconnect (75 Ohm)..."
    Is this the right kind of connection cable for what I need it for? DVD to AV amp?
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Yes, 75Ohm is what you want for a digital conection. :thumbsup:
  3. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Thanks. I was worried because they don't make a big thing out of this being a 75 Ohm cable. I thik most coaxial / digital cables are 75 Ohm though aren't they?
  4. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    audio are generally 50 Ohm and digital 75 Ohm. :thumbsup:
  5. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
  6. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    looks good for your needs:
    Highest quality audio interlink; Tone arm to preamp (*); Microphone or Electrical instrument cable; SPDIF digital audio interconnect (75 Ohm) :thumbsup:
  7. bobbypunk
    bobbypunk
  8. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Thans guys!! :thumbsup:
