DVD player sugestions
Discussion in 'Projectors, Screens & Video Processors' started by jamest, Sep 17, 2001.
  1. jamest
    jamest
    Sep 17, 2001
    53
    Hertford
    Have just equipped my freshly built home cinema with the Sony VPL-VW10HT projector and want to take advantage of the progressive scan compatibility. My current DVD player (now 2years+ old) doesn't have this capability so want to upgrade.
    Any suggestions? First thought is the Pioneer 737 but this will only work with NTSC dvds. Are there any PAL PS players available or in the pipeline?
    Any advice much appreciated.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
  3. z5461313
    z5461313
    Sep 18, 2001
    1,713
    +265
    Hello
    Do you know how the Denon 2800 compares to the Skyworth for PAL progressive as I have read that there are problems with the video quality
  4. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    Hello<br />i have a pioneer 737 which untill recently ran through a plv-30 the results were quite good when in progressive scan this however was only any good with ntsc material, then bough an iscan which offered an even better picture a lot clearer and cleaner and was even better on pal material because the iscan converted the pal material in to pal progressive scan,but i agree with Gordon the denon dvd 2800 is a very good player with the silicon image processing already built in but i can't comment on the difference in quality between the 737 + iscan against the denon player but from a financial point of view i would advise checking out the denon.
    regards
    <br />richard
  5. Metric
    Metric
    ive got the denon 2800 and sony wht10, looks great, it used the dvdo chipset, same as the iscan i beleive. I dont know why youd pay for a 737 and iscan, surely a cheaper panasonic decoder based dvd with the iscan would be better and cheaper
  6. Metric
    Metric
    Denon apparently say that changing the firmware wont effect the warranty
  7. jamest
    jamest
    Sep 17, 2001
    53
    Hertford
    Thanks for advice. Looks like the Denon is my man - do you where I can buy a region modified UK version (if at all)? Obviously it needs to play RCE DVDs too.
    Can't find anywhere confirmation that this player outpouts progtessive PAL either!
  8. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    James,
    It does output PAL once hacked. Any UK Denon dealer can supply one. They come region2 as standard though. Your dealer would have to do the hacking. Or you can download firmware off the net and burn a CD for yourself to do it.
    Do a search on the forums for post by Ian Guinan about this model for further info.
    Gordon
  9. museumsteve
    museumsteve
    Jan 28, 2001
    8,005
    4
    Nth Hampshire
    +1,109
    after reading this thread...does this mean a projector that offers Component input can handle progressive scan..?? I have a Sony CS3 and a Pioneer 939A and would love to use PS (as I used to have a Plasma with it)..someone put me right..please..
  10. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    No I'm afraid it doesn't. The YPbPr component signal standard can be used for carrying different scan rates of signal, both interlaced and progressive. So it's feasible that a projector will accept the interlaced signal carried down a component cable but not the progressive one.
    To check you want to make sure that the projector or display device in question has the ability to have at least a 32kHz vertical scan rate (for line doubled pal/ntsc).
    Gordon
    [ 27-09-2001: Message edited by: Gordon, Convergent-AV ]</p>
  11. terryc
    terryc
    metric,would you please clarify.You say you have the Denon 2800;does it output progressive scan in PAL and if so could you let me know where you got it.My local dealer has'nt a clue.
  12. Rupert Bear
    Rupert Bear
    Dec 12, 2000
    13
    Reigate, Surrey, UK
    Gordon's post says that "It does output PAL once hacked." I don't understand why a region 2 machine that has "progressive scan" emblazoned on its fascia needs to be modified to output progressive PAL.
    I play almost exclusively region 2 discs through a Sanyo plv-30 so would be very interested in a machine which made use of the Sanyo's progressive scan capability.
    Gordon, can you explain ?
    Rupert
  13. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Rupert Bear: It has to be hacked to output Pro-scan PAL because there is currently no official PAL pro-scan standard, or licensing for it, so it is, strictly speaking illegal, form DVD players anyhow.
  14. Rupert Bear
    Rupert Bear
    Dec 12, 2000
    13
    Reigate, Surrey, UK
    Richard,
    Thanks for the explanation.
    Rupert
