DVD player recommendations?
Discussion in 'Blu-ray & DVD Players & Recorders' started by jonny, Nov 14, 2000.
  1. jonny
    jonny
    Aug 14, 2000
    285
    Hertfordshire
    +3
    Hi, ive got £250-£350 (maybe a bit more if its really worth it) to spend on a new dvd player and im totally confused as to which ones to shortlist.
    It must have an optical output, and be multi region (or able to be modified) I dont want lots of features on the player like bookmarks, just the basics will do. Id rather cut out all the bells and whistles and go for a player with superior picture and sound quality. It must also have good CD playback as i will be using it as a CD player aswell.
    Id be gratefull for all your advice and recommendation, Jon.
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,537
    Newcastle
    +330
  3. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    I have a Hitachi 505 and it gives good all round performance.
    If you are not really interested in macrovision disable you could get it from Dixons for 270 on a years interest free, then download the multiregion firmware from my site.
    you can pick one up multiregion & macrovision disabled for 300.
    It also plays MP3's
