DVD player recommendations anyone?
Discussion in 'Blu-ray & DVD Players & Recorders' started by darklight, Jan 21, 2005.
  1. darklight
    darklight
    Oct 8, 2004
    1,120
    Portadown, N. Ireland
    +109
    My Panasonic RV41 seems to have went to the great scrap heap in the sky so I'm on the look out for a new multiregion player.
    I've a budget of around £140 and would like to upgrade to a RGB Compenet compatable player as my TV (Panasonic TX 36pd) supports the progressive scan RGB with component connections.
    I've heard good reports about the Yamaha 550. All recommendations are welcome. :)
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    A frequent recommendation round here is the Pioneer 575 (c. £149 or less), not had any experience with it myself but a quick scan of recent threads will give you a good idea of what people think of it.
  3. darklight
    darklight
    Oct 8, 2004
    1,120
    +109
    Does it matter if the DVD has Prgressive Scan for PAL only. What I mean is what's the advanages of NTSC/PAL scan
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I think it means that if you try to play an NTSC DVD it'll output 480i instead of 480p, so the display will have to do the de-interlacing. If your DVD collection is entirely or mainly region 2 PAL then of course this isn't an issue, if you have a number of R1s then it may be something to consider.
    That said, the Pio 575 is dual-mode progressive, according to this on-line ad.
