DVD Player recomendations?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Enid, Aug 3, 2005.
  1. Enid
    Enid
    Hi guys,
    My Marantz DV4100 OSE has given up the ghost so i'm on the loom out for a replacement. The player will double up as my CD player also so good sound quality is a must. I have a budget of up to £300. I will be mating it to a 32" Panasonic 100hz CRT (Via RGB SCART) and Marantz SR4200 amp (Via digital co-ax).
    Any suggestions glady appreciated.
    Cheers.
  2. loadsofleads
    loadsofleads
    Personally I have never touched any other DVD except Pioneer, My 757 is over your £300 budget though, just make sure there is 'Pioneer' written on the front and you can't go wrong imho. :thumbsup:
  3. spiver
    spiver
    Dec 26, 2004
    1,111
    48
    +33
    How about a Sony?
    I have a Sony DVP-NS930 running through a Sony 42" Plasma. Its great, beautifully finished, easy to use and superb picture and sound. I had the NS900 before that - superb. I think the new DVP-NS955 has DIVX playback whereas the NS930 doesn`t, but I have just pulled that off a few websites so I can`t be 100% sure. In addition you will get SACD playback if that is a factor. Both the my Sonys have been pretty good with music too. :smashin:
  4. mjbtin
    mjbtin
    Jan 13, 2005
    2,174
    +446
    try the limit dvda900se available from www.play.com for 49.99,the limit has been
    tuned by british high end audio specialists Cyrus.Audio from this player is excellent and PQ via RGB is very good.If you search this forum it will tell you
    all about this machine :thumbsup:
