DVD Player - Progressive Scan
Discussion in 'Blu-ray & DVD Players & Recorders' started by Pip_UK, Jan 14, 2002.
  1. Pip_UK
    Pip_UK
    I am buying a DLP projector in a couple of weeks.
    Is it worth getting a progessive scan DVD player if the projector has on board high-end de-interlacing, per-pixel motion compensation, 3:2 and 2:2 pulldown film-mode detection and cross-color suppression (Faroudja)
    I was opting for the Sony DVPNS900V
    Pip
  2. Guest
    Which Projector are you talking about ?
    Sim HT300 perhaps.
    With the onboard Faroudja de-interlacer onbaord all you really need is a DVD with a quality component output.
    The projector will be doing most of the work.
    There's been quite a few problems with Sony 900's
    Owl have been reccomending Arcam DV88's to use in such a scenario
  3. Pip_UK
    Pip_UK
    Thanks,
    The projector is Tosh's DLP MT5 (2m screen from 3.8m viewing distance)
    What was the probs with Sony? ... I need a DVD player with component output and the reviews seemed better than the Tosh equivelant.
    Cheers,
    Pip
  4. Guest
    Pip,
    I'm not sure of the exact problem with the Sony 900
    Do a search on this forum based on the model number and you should find something.
    It may not be relevant to component out ??
    Regards,
    David
