DVD player problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Geezer, May 11, 2003.
  1. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    Not sure if this is the right forum for this if not mods please move.
    Im probably not going to explain this too well so bear with me :rolleyes:
    Right i have a Sony 7700 dvd conected to my Sony TV KV-32FD1E it is connected with QED SQUART running via RGB. Now when playing i seem to get blurry images when things move on screen, they dont even have to move fast. And it looks quite pixilated sometimes too, is there anything i can do to solve this? also all my sky channels through coaxial on tv have gone really bad recently they are fine on rgb.
    Thanks in advance
    Geezer
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,179
    UK.
    +2,716
    Is your tv 100hz?
    100hz tvs can cause terrible smearing on moving objects due to the way they produce the image - it uses a buffer for two images, and if the 1st is a little out of line with 2nd, you'll get smearing.
    Also, make sure all processing is turned off, and that the sharpness is at least below half way.
    The processing 'features' tend to introduce artefacts into the image, an having the sharpness too high will make the tv try to define any edges, such as pixels and blocks. This will make digital broadcasts look more blocky, and backgrounds can be made to look alive as the various colour shades are made distinct rather than blended. Backgrounds can tend to look alive with crawlies and moving dots.
    HTH
    Gary.
  3. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    No its not a 100Hz tv
    ill try the other things you mentioned.
    Anyone else?
  4. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    Any other suggestions?
  5. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,882
    3
    48
    +79
    It's not this is it?
    "Picture shading with DVD player
    Model: KV-28FD1E, KV-28FD1K, KV-28FD1K/3, KV-32FD1E, KV-32FD1K, KV-32FD1K/3
    Sympton: When playing back certain software using a DVD player, a shadow may be observed on the screen
    Solution: On the B1 Board, replace IC317 PC83C654EBA565 (8-759-470-81) with P87C6544A44 (8-948-007-24)"
    http://www.multimod.com/uk/shop/trouble-shootings/0004-Sony-TV.html
    Otherwise,try routing it via a Video etc,or trying a different DVD player/TV.
  6. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    No i dont think thats it, sounds like a different problem.
  7. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,882
    3
    48
    +79
    Have you tried RGB off?
  8. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    No i havent actually , will try later.
